Thread: Neutrilizing acid after no drain acid wash
    Hi all,
    Had a no drain acid wash on my pool that started on Tuesday. I added 20 pounds of sodium carbonate yesterday afternoon. This morning my PH is still way low. Does this process take time to raise PH after the sodium carbonate is added? Should I add more or wait? My PB has been useless.
    Thanks.
    Let me add that the pool is a 18,500 gallon River Rok plaster pool
    Re: Neutrilizing acid after no drain acid wash
    How did you add the sodium carbonate?
    Typically, you can assume it is mixed in the pool after an hour with the pump running, and re-test. The recommended way to add it is to pre-dissolve it in a bucket of water, and then pour slowly in front of the stream of water coming into the pool through one of the returns.
    Outdoor 14,000 gallon IG plaster pool built in 2000 with spillover spa, 2 hp WhisperFlo pump with MagneTek motor, Sta-Rite cartridge pool filter with 300 ft2 filtration area and 0.33 gpm/ft2 filtration rate, Aquabot Rapids 4WD robotic pool cleaner, Raypak digital gas heater, and Intermatic mechanical timer located in the Dallas-Fort Worth metroplex
    Thanks for the reply. I can't run the pump as I have to wait until the PH comes up. However, there are 2 pumps in the pool that are circulating from the acid wash. I just sprinkled the carbonate in and I've brushed it all day. I did add more but no difference. I am ready to just drain the entire pool and fill at this point.
