Thread: Solar Bear Roof Mount
    What hose should I use to connect? Black flex PVC or the white spa flex PVC? Need about 100ft of whatever I'm going to use.......
    AG 10,400, Sand Filter, 1.5hp pump
    30,432
    Re: Solar Bear Roof Mount
    Welcome to the forum.
    I think folks need more info from you to respond.
    I have a 21ft round above ground pool with a 1.5 HP pump. Its fully enclosed in a screened in deck. I purchased a 4x20 fafco solar bear solar kit and I'm planning to roof mount it. I've seen people use all kinds of hose to hook these things up poolside but I'm not sure what's best to use for extending to the roof. All my pipes going from pump to pool are hard PVC not flex. Not sure if that matters.
    38,514
    It would be best to use hard pipe PVC for everything you can.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    As Jason said, hard PVC is usually the best
    There are several DIY solar install threads on the board here, I would suggest looking through some of them for general information and ideas. Try typing "solar panels" into the search box in the upper right
