Results 1 to 15 of 15
Thread: ambient water temp
    Jul 2012
    Whidbey Island, WA
    397
    ambient water temp
    So now begin to understand costs of heating pools in Western Washington.
    Ambient water temp seems to be about 70 in August. And to get to 85 for toddlers costs a bit of $$.
    What is the ambient preheated water temp in S Florida, S Texas, Arizona, S Calif, etc?
    IG under fir trees and one cherry surrounded by grass built in 1979, 30k, plaster, old Sta-Rite HRPB30, 4.9 sq.ft, 20 GPM/sq.ft., but with new glass, new (in 2012) 1 HP WhisperFlo one speed, new (in 2013) Rainbow tab chlorinator attached at the top, old Maxi-Flo Heat Exchanger MF-260, Burnham V7 oil heater 245 MBH, new (in 2012) Compool to Easytouch, Taylor K-2005 and TF-100.
    Aug 2010
    Dallas, TX
    4,052
    Re: ambient water temp
    We have very large pools on my street as you can see by my sig line. The person across the street from me has a gas heater, and told me that it can cost him $1,000 a month to heat during cool months. I cut my heater out and took it to the recycler when I installed my SWG. I can still swim right now with no heater so I don't see the point.
    mas985's Avatar
    Pleasanton, CA
    11,737
    A unheated, non-covered pool will have a temperature that is pretty close to the average air temperature. So it really depends on the weather/time of year. I've had close to 15 degree gain with just a solar cover and although I have solar panels, I hardly ever use them when I have the cover on the pool and I can still maintain 85 degree water temperature.
    Mark
    30,404
    My pool performs almost exactly as mas985 states.
    If my daytime high is 90 and low is 70.....I have 80 degree water
    If my daytime high is 50 and low is 30.......I have 40 degree water.
    Each climate is different and relative humidity can play a large role but mas985's statement is a very good guideline.
    Dallas - Fort Worth area, 84-86 water temperature right now.
    You can look at this thread to see water temperatures reported throughout the season from different locations, some with solar, some with covers, and so forth: what-s-your-current-pool-temp-t41-1320.html#p584771.
    Outdoor 14,000 gallon IG plaster pool built in 2000 with spillover spa, 2 hp WhisperFlo pump with MagneTek motor, Sta-Rite cartridge pool filter with 300 ft2 filtration area and 0.33 gpm/ft2 filtration rate, Aquabot Rapids 4WD robotic pool cleaner, Raypak digital gas heater, and Intermatic mechanical timer located in the Dallas-Fort Worth metroplex
    Jul 2012
    Whidbey Island, WA
    397
    Quote Originally Posted by danacc
    wow 84 Las Vegas in June
    lots higher than ave temps here in Pacific Northwest
    high average temp is 65 in August
    so lotsa BTUS to heat
    but then, how much is a grandbaby giggle worth and
    but then, heating will cost less after some climate change and
    but then, I will be dead by then and
    but then, will benefit the kids
    thanks for the info
    In the Orlando FL area:
    We fill with well water - constant 72 out of the hose.
    Day time temps - 95 to 98 in the summer. A lot of direct sun.
    Water temp - we've been pretty consistent between 88 and 92 depending on the amount of sun we get that day.
    This last week we've been under clouds and rain (which is more the exception not the rule, and we're down to 82 in the pool!!
    15,000 gal, IG, Vinyl
    Cartridge Filter: Hayward C12002, 120 GPM
    Pump: 1.5 hp, Flotec AT251501-01
    TF-100 Test Kit
    Jul 2012
    Whidbey Island, WA
    397
    Quote Originally Posted by Nplsdvr
    Down to 82?
    Down to 82?
    My heater works all day to get to 82
    I wonder why the previous owner built the pool
    Maybe energy was cheap then
    30,404
    Heating a pool will be a major expense in your climate. Do you have a solar cover?
    Quote Originally Posted by engrav
    Down to 82?
    Down to 82?
    I guess you don't want to hear about the first day of sunshine in 5 days and we're back at 88, huh?
    TF-100 Test Kit
    Mar 2012
    Tampa Bay, Florida
    166
    Down to 82?
    Down to 82?
    All I can tell you is that when I first moved into my house in 1985, propane was 50-60 cents a gallon with no tank rental fee (I don't own the propane tank). Now, propane is $4.60 to $5.00 a gallon with a $50/year tank rental. When we moved here, we heated the uncovered pool to 86 almost every weekend up to the first of the year. Now, I only use the heater for the spa. I could easily see it being $1000 a month in the Winter here in FL to do the same as we once did for about $130 a month. We are running about 80 degrees her in the Tampa area (actually 77-78 in the AM and about 80-81 by 4:00 PM). We just got out of a 3 day cloudy/wet period.
    John (DIYer). Concrete, approximately 13,000 gallon in-ground pool with adjoining concrete spa. Approximately 40 years old. Hayward Super II pump for pool and legacy Anthony Sta-Rite bronze pump CF6 for spa, VA-26 filter,(2 sets), Rheem propane heater for spa. HASA Liquidator for pool.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by mas985
    Is this from using one of those "bubble" type solar covers?
    Essential Links:
    mas985's Avatar
    Pleasanton, CA
    11,737
    Yes, a clear bubble cover.
    Mark
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Definitely use a cover. Looking at the last two weeks here, I would expect my pool temp to be around 62F without a cover or the solar heat. With them, we are still swimming and should be up to 74F pool temp today. I estimate about 2/3 of the increase is due to the cover, and the rest due to our solar heating (used "religiously" whenever there is sun on the panels to heat with). This time of year, our pool area is fairly shaded and gets good sun only about 3.5 hours/day and our solar panels only get some sun for about 5 hours/day now.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    This applies to my pool. It gets full sun, but has a deep end. I also notice a bit of a thermocline when I first get in and start doing laps as some of the cooler water from the deep end mixes with the warmer water at the surface. This is most prevalent in late morning/early afternoon on sunny days. Average depth, sun coverage, and surface color will also play a role in ambient water temps.
