Thread: Backwash and DE filter
    Sep 2013
    DFW Metroplex
    119
    First time pool owner, did my my first back wash on my own, previous owner left me a note saying after backwash fill the skimmer with 10 scops of DE, do I need to do that? Also,backwash drained around 1 and half inch of my pool water, is it normal?
    13K gal, IG, Gunite pool with raised spa water spill over to pool, built on 2005
    1.5 HP Hayward MaxFlo VS - June 2014
    DE Filter Model # DE6020
    Added Borates on Jun 2014
    Aug 2010
    Dallas, TX
    4,052
    Re: Backwash and DE filter
    You do have to recharge a DE filter after backflushing . It was nice of the PO to leave you a note telling you how much. Yes, backflushing drains water from your pool.
    Hello from another suburb of Dallas.
    For the DE6020 you should use 6 pounds of DE after backwashing or 8 pounds after a full cleaning. DE is about 48 ounces (volume) per pound.
    1.5 inches is too much water to use. Although, your pool is rather small and would take a noticeable amount. What is your backwash procedure?
    Support the site
    Sep 2013
    DFW Metroplex
    119
    Quote Originally Posted by RobbieH
    Thanks, I will make a trip to Leslies to get DE, I won't give any credit to my previous house owner ,he didn't maintained the pool properly after the option period and until the closing (46 days), I am still fighting the algae he left behind.
    Sep 2013
    DFW Metroplex
    119
    Quote Originally Posted by JamesW
    My backwash procedure:
    1. Turn the pump off.
    2. Turn and pull up the back wash handle.
    3. Turn the pump on and run it for 2 minutes.
    4. Turn off the pump.
    5. Turn and push down the back wash handle.
    6. Turn the pump on for 15 seconds.
    7. Repeat steps 1 to 6 for 3 times.
    8. Load the skimmers with 10 scoops of DE.
    9. Run the pump normal and make sure pressure gauge shows the pressure less than 18 and if it reaches 23 time to backwash.
    Quote Originally Posted by missourian
    2 minutes is probably a little too long. 30 to40 seconds is probably enough. Watch the sight glass to see when the water clears
    Support the site
