Thread: ORP vs ppm
    ORP vs ppm
    Am interested in the correlation between ORP and ppm free Cl2, and relationships with pH and CYA. Are there any charts available?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: ORP vs ppm
    Welcome to the forum Jim!
    We have a couple of Chlorine/Cya charts here actually. If you check out the links in my sig, you will find them in Pool School.
    As for a FC chart correlating with ORP, it is only possible in theory. Rarely if ever will mV to FC be accurate in practice because ORP readings are greatly influenced by many factors...pH being only one. Even in systems where conditions are "perfect", accurate control of FC via ORP is not easy to nail down.
    Essential Links:
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: ORP vs ppm
    See this post and the rest of the discussion in that thread.
