Results 1 to 15 of 15
Thread: Rough guess for drain time of a 16x48 Intex with one hose
    Jun 2012
    Michigan
    154
    Hey everybody. I have to drain a 16x48 Intex pool this weekend, but is there any way to figure out roughly how long it should take to drain the thing? I just have one hose and drain plug thing to put on the hose.
    Intex 16x48 UltraFrame AGP, included filter pump
    Re: Rough guess for drain time of a 16x48 Intex with one hos
    I suspect 2-3X as long as it took to fill it, since you won't have as much pressure leaving as you did coming in..........
    If you have been using a vacuum hose, it's fairly straight forward to start a siphon with that, as long as the end outside the pool is lower than the end inside, although the neighbors will look at you funny when they see you sucking / inhaling the end of the hose to get the siphon started
    24 foot AG Vinyl, 10 year old wall, 1 year old liner
    Hayward 240T Sand (free!)
    Hayward 1.5 hp pump (free)
    BBB just ROCKS!
    Jun 2012
    Michigan
    154
    yeah, i'm just trying to figure out a rough guess of how long, so I know when to start it so I can take it down right away once it's empty
    mas985's Avatar
    Pleasanton, CA
    11,742
    What size is the hose? (e.g. 5/8" or 3/4")
    How long is the hose from edge of pool to the end?
    Will there be any change in elevation from the pool to the end of the hose?
    Mark
    Jun 2012
    Michigan
    154
    not sure on the hose size to be honest, I didn't even know hoses came in different sizes haha.
    I think the hose is 50ft, and it will go down my driveway, so the end will be slightly lower than the pool.
    mas985's Avatar
    Pleasanton, CA
    11,742
    Assuming a 5/8" hose and 50' long, it would take about 26 hours.
    Mark
    38,521
    Rough guess ... 15-45 hours
    Well at least Mark's value fell in my range
    Jun 2012
    Michigan
    154
    Thanks guys, that's exactly what i'm looking for. Glad you were in agreement
    May 2013
    Janesville WI
    74
    my 18' took about 3 days and I had about the same length that you were going for....it is slow going.
    Intex 18x48/2650 Sand/56601E SWG
    Jun 2012
    Michigan
    154
    Thanks dtmos
    Jun 2012
    Pennsylvania
    44
    We have the same size pool. I started ours by vacuuming to waste, then back washing and rinsing and then continued to waste until the water was down to the intake port. I started this on a Thursday night around 8pm. The rest was left to the garden hose, about 50' going down a slight hill. By Saturday morning it was empty, aside from the water that was below the drain. I'm not sure when it actually got to empty because I wasn't really watching it. I just wanted it empty by Saturday morning and it was.
    16'x48" Intex Ultra Frame Pool
    Intex 2650gph Sand Filter Pump
    Intex SWG
    Jun 2012
    western NY
    1,562
    Get an empty 1 gallon jug and fill it with the water from the hose when you are draining it. Time how long it takes and multiply by the numbewr of gallons in the pool. For example...assume it takes 1 min to fill the jug from the siphon hose and the pool is 6000 gallons. It would take 6000 min to drain the pool. Divide that by 60 ( min /hr) and that will give you 100 hrs
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Jun 2012
    Michigan
    154
    It's looking like mine, purely based on the hose only, is going to take somewhere in between 2 and 3 days. And of course it rained all day one of the days haha.
    Jun 2012
    western NY
    1,562
    last time I had to drain mine (liner replacement) I used my vacuum hose for a siphon hose as well as two garden hoses. 6000 gallon only took about 4-5 hours
    Jun 2012
    Michigan
    154
    I only have the vacuum that came with it, which just adds water to the pool
