Results 1 to 10 of 10
Thread: Single speed pump on waterfall
    Atlanta, GA (Dunwoody)
    59
    Does anyone know if there is a device to convert a single speed pump to variable...like a dimmer? I have a waterfall and sometimes want to slow down the pump so water dribbles down the rock face of my wall.....looks really nice. I know this, because when the leaves start falling or the pump looses prime, the pump slows down.
    Thanks in advance.
    Heinsite
    17500 pool/spa iAqualink Rev R, Pentair VSF, Pentair DE Filter, Waterfall, 3900 Polaris Cleaner, Goldline Saltwater Gen. w/t15, Rayvac 40,000 Gas heater, Taylor K-2006 Test Kit, Taylor Saltwater Test Kit
    38,524
    Re: Single speed pump on waterfall
    No such thing. The motors are not designed that way. You can add a valve after the pump and partially close it to reduce the amount of flow however.
    59
    So does restricting water add strain to the motor? (obviously, no water burns up the impeller)? Thanks for the reply
    Heinsite
    mas985's Avatar
    Pleasanton, CA
    11,742
    Actually it is just the opposite. The more head loss in the system and the lower the flow rate, the lower the load on the motor.
    Mark
    Sep 2013
    Auburn, Alabama
    73
    Adding a valve after the pump is the way to go.
    There are remote actuated valves that could accomplish what you want.
    The Original Leak Specialists.
    59
    I have a three way valve before pump, would it damage the pump restricting inflow there?
    Heinsite
    38,524
    You do not want to restrict it before the pump ... Why is there a valve before the waterfall pump?
    59
    Not sure why a valve, but feeder from Pool to valve (obviously) then one to the pump and the return to the waterfall which has a leg back to the valve. New questions as I am having trouble priming...replaced O rings on valve, opened and re-magic lubed the basket and freeze plug...opened the fuser and inspected the impeller which was clogged with debris and a plastic shard (blue, misc. piece) in the impeller. ONE of the back fins is broken on the impeller, will this keep it from priming and pumping?
    Heinsite
    mas985's Avatar
    Pleasanton, CA
    11,742
    Quote Originally Posted by Heinsite
    Yes and it could damage the pump motor as well because of the imbalance it will cause so you might want to repair that ASAP.
    Mark
    59
    Ok, just ordered one...Thanks again for all the help
    Heinsite
