Thread: Any chlorine fumes from Liquidator?
    I'm considering getting the Liquidator, but I'm a little worried about chlorine fumes.
    All the pictures I see from people who are singing its praises have the Liquidator installed outdoors. In my case, it would be installed in a pump room with reasonably poor ventilation. The lid of the Liquidator is obviously not designed to make an air-tight seal.
    Having been hit with chlorine fumes from opening up a puck chlorinator, I am very wary of anything that could cause a buildup of chlorine fumes, especially in a room where I'm not the only one with a key. The Liquidator marketing materials say that the layer of water on the top "minimizes" chlorine smell, but doesn't say "eliminates".
    Also, would the heat from the warm pump room accelerate the release of chlorine vapors?
    25000-gallon semi-public IG concrete/plaster pool, Triton II sand filter
    750-gallon semi-public IG concrete/plaster spa, cartridge filter
    Volunteer pool caretaker for my condominium complex
    22,549
    Re: Any chlorine fumes from Liquidator?
    Due to the nature of the LQ (liquidator) with the water sitting on top of the bleach, there is virtually zero fuming. It's about like sitting a tub of tap water out. The largest fuming exposure you're going to have is when you open the bottles to refill the LQ.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Nothing at all. Not even an odor. Mine is in a pump room as well.
    Aug 2010
    Dallas, TX
    4,052
    Mine was in an enclosed room also, no fumes issues.
    Awesome. Thanks!
