Thread: End of season PRAISE for BBB
    Feb 2012
    Maryland
    400
    My DIY pool was complete the first of July. I used water out of my well which tested negative for any metals (AMAZING)
    I started with just adding bleach and brought FC to around 6 or 7 (dont rememeber now) and CYA.
    I then switched on my salt cell. I started testing everything daily. After I saw how stable it was I went to every couple days. I then went to simply checking FC every couple days and all other parameters weekly.
    During the summer the only thing I added was Muriatic Acid due to PH rise. I went through 5 bottles all summer.
    My water was and is sparkling clear. People raved about how perfect it looked. I never once had to SLAM, it just ran smoothly.
    While building the pool all I heard from family and friends was how much maintenance it would be. How the chemical process would be costly and messy.
    The absolute BEST thing I did was get the SWCG. That addition took literally 90% of any maintenance away!
    Kudos to BBB!
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: End of season PRAISE for BBB
    Congratulations to you on getting it right. That is how it's done!
    Essential Links:
    Feb 2008
    Denton, TX
    5,061
    Strong work! And not that hard at all was it?
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Great Job!
    Another example of how pool care doesn't have to be complicated.
