Results 1 to 14 of 14
Thread: petroleum jelly on pump gaskets?
    Chewbubba's Avatar
    Jun 2012
    Russellville, AR
    127
    So, looking in the manual about storage of the Krystal Clear 635T, and it said to coat the gaskets in petroleum jelly and store in an airtight plastic bag.
    1) Isn't petroleum jelly rough on rubber products?
    2) Isn't that going to be nasty getting off the gaskets next season?
    3) Would something water-soluble like K-Y jelly be a better substitute?
    16x48 Intex Ultraframe vinyl AGP, 2150 gph sand filter/pump (Intex SF70110), Hayward Skimmer, TF-100 test kit
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: petroleum jelly on pump gaskets?
    You should only use silicon grease (e.g. pool lube) on o-rings and gaskets.
    Mark
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Like Mark said, use silicone grease (not silicone adhesive) on rubber parts, not all rubber is the same though, most common O-rings are now made from Buna-N rubber, and it is possible, but somewhat unlikely that the O-rings used supplied with your 635T are made of a material that is more resistant like Nitrile, these however cost about 5-10 times the price of more common
    Aug 2009
    SW Wisconsin
    518
    do NOT use petroleum based products..it'll slowly eat away at the o rings and gaskets. As mas985 said....get some pool lube.
    33' x 52" Swim and Play Inc. PARAGON AGP. Hayward H200 Heater. Hayward Power-Flo LX 1.5hp pump. Sta-Rite Cristal Flo T-210WF Sand Filter. Stenner 45M5 chlorine pump
    Chewbubba's Avatar
    Jun 2012
    Russellville, AR
    127
    Will my local pool store probably have this stuff, or do I need to look online?
    Aug 2010
    Dallas, TX
    4,052
    Pool stores have it.
    Jun 2007
    New Jersey
    653
    Pool stores have it, but around here they sell you a miserable little 2oz. tube for a ridiculous price. I went with this deal on Amazon, which is 2 - 5oz. tubes for $12.48 with free shipping. So compare before you buy.
    http://www.amazon.com/PACK-Aladdin-T...ords=magiclube
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    May 2013
    North East Ohio
    959
    I thought we should use silicon only ?
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    Silicone lube is the best solution. Magic Lube II is silicone based lube. Regular Magic Lube is Teflon based. I find that Teflon based lubes tend to gum up and makes things sticky and hard to work with.
    Support the site
    Chewbubba's Avatar
    Jun 2012
    Russellville, AR
    127
    Thanks for all the information folks! If I get a chance, I'll go by the pool store tomorrow.
    Chewbubba's Avatar
    Jun 2012
    Russellville, AR
    127
    Grrr. I went to the pool store. The only lube they had was Magic Lube. No "silicone" or "teflon" mentioned anywhere on the ingredients, packaging or the display box. I brought it home to look up what "PTFE" is, and it turns out it's teflon.
    Is it really worth the gas and hassle of taking this back and finding silicone-based stuff at the hardware store?
    I don't like teflon based lube. You will probably need to go online to find silicone lube. Boss 820 is a good lube for a good price.
    Support the site
    Mar 2012
    Tampa Bay, Florida
    166
    I get my silicon lube at Home Depot in the plumbing Dept. It is sometimes called plumber's grease by those in the trade. It is usually food grade rated since it can be used on the O-rings for water faucets or scuba gear. A small 50 cent piece sized tub should only be $4-$5. Dow Corning also sells a food grade silicon grease in a tube.
    Here is one possibility:
    http://www.ebay.com/itm/McNett-M-Essent ... 1c35849ded
    John (DIYer). Concrete, approximately 13,000 gallon in-ground pool with adjoining concrete spa. Approximately 40 years old. Hayward Super II pump for pool and legacy Anthony Sta-Rite bronze pump CF6 for spa, VA-26 filter,(2 sets), Rheem propane heater for spa. HASA Liquidator for pool.
    Chewbubba's Avatar
    Jun 2012
    Russellville, AR
    127
    Yeah, I just got back from Lowe's, and picked up some Oatey Silicone Grease. It was only $3.33 for 1/2 an ounce.
    I'll take the teflon stuff back tomorrow.
