Thread: My closing plan, please review
    Feb 2012
    Maryland
    400
    I plan to close sometime late October early November depending on the weather. Amazingly my water is still hitting 78-80 and the kids are still enjoying it!!
    here is the plan :
    Prior to these steps I will pull filter drain and let water drain from there,. Then ill put filter drain plug back in.
    **** Not lowering the water much, just to the bottom of the skimmer.
    1. Put multiport on recirculate
    2. Install skimmer gizmo with valve to blowout
    3. Install plugs into ALL returns except 1.
    4. Connect mightyvac to skimmer gizmo
    5. Set 3 way valve to block off MD
    6. Set valves open for all returns (step jets, deck jets, wall returns)
    7. Turn on air, wait for air to start blowing out.
    8. Once blowing, screw in screw in plug to the one blowing and open the next one.
    9. Repeat 8 until all returns are plugged.
    10. Close 2 way valve leading to pump from 3 way which has skimmer and MD (currently MD is blocked). This will block aire from going into the pump and will direct it all to MD.
    11. Switch 3 way to allow air to flow into MD.
    12. Let MD bubble then close 3 way back to block off MD.
    13. Reopen 2 way to pump, set filter on waste and blow until air comes out of waste.
    14. Remove plugs from pump and filter, place in pump basket
    Im not using antifreeze. All my pipes are 3 feet below ground. The only place where this isnt true is where the come out under a retaining wall to the pump pad. Pump pad is below water level. I have maybe 3 feet of pipe that is only about a foot below ground.
    ***** ive read about winterizing steps. Should I put milk jugs half full on the steps?
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: My closing plan, please review
    I don't understand what you mean about milk jugs on the steps. can you elaborate or maybe I'm just missing it.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Feb 2012
    Maryland
    400
    A friend of mine who has a pool company close his, he said they fill 10 milks jugs half full and tie a string on them to tie to something heavy so they dont float away. He said he thought it was so the water didnt freeze solid and crack the steps, sort of like how the gizmo works in the skimmer.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    I guess it wouldn't hurt, I've only seen a skimmer get damaged by ice freeze. Steps usually break from not being back-filled / supported properly.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
