Results 1 to 7 of 7
Thread: adding chemicals
    May 2013
    Cyprus
    159
    adding chemicals
    Hi all
    When I add chemicals to the pool I do so in front of where the vacuum hose is fitted. Should I have the multi valve set to filter or recirculation.
    Living in Cyprus
    Still enjoying life
    38,290
    Re: adding chemicals
    You should be putting them in front of the return jet ... water going back into the pool. Filter setting does not matter.
    To clarify, most are poured in front of the return jet. The recommended pool chemicals article in Pool School explains how to add each chemical.
    May 2013
    Cyprus
    159
    Sorry I am a tad confused I have 5 return jets in my pool all at the bottom 2 at the deep end 1 on the slope and two in the shallow end, whilst if I use the vacuum port and have the multi valve set to recirculation the chemicals are dissipated more effectively. I am probably missing something basic?????????
    Living in Cyprus
    Still enjoying life
    22,549
    Is the vacuum port pressure or suction?
    May 2013
    Cyprus
    159
    The vacuum port is suction which is located at the deep end of the pool about 9 inch below the surface. Their is a main drain located at the bottom in the deep end which is suction and the five returns which are pressure, the pool is a overflow type.
    Living in Cyprus
    Still enjoying life
    22,549
    Adding chems thru the suction of the pump isn't recommended. Depending on the chemical it can be very bad for system internals (pump, filter, heater, etc.) in concentrated doses. Since you only have floor returns, I'd pour it over one of them and then brush near it to ensure good mixing.
    May 2013
    Cyprus
    159
    OK
    Thanks for that will stop using the vac.
    Living in Cyprus
    Still enjoying life
