Thread: Need experts opinion on my readings
    I have a slight algae bloom going on. My numbers are below.
    Total chlorine 8.8
    FC. 6.8
    PH. 7.4
    ALK. 90
    CH 175
    CYA 45
    Have been advised to use some algaecide, is that the fix?
    AG 24' ( Columbia PL30-6 sand filter), 2hp 2 sp pump, cholorine, Tennessee
    Taylor k- 2006 test kit
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    No algaecide is not the answer. This is the answer pool-school/shocking_your_pool.
    This process has to be followed to the T.
    Your done SLAMing when
    1 water is crystal clear.
    2 CC of 0.5 or less.
    3 you pass the OCLT. pool-school/overnight_fc_test
    Do you have one of our recommended test kits ? Make sure you do some reading in pool school so you have an understanding of water chemistry and so forth.
    Jeff
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Need experts opinion on my readings
    pwrstrk gave you good advice. Algaecides can be insurance to help keep algae from starting (although we generally don't recommend using it for regular pool maintenance on tfp), but once algae gets started then chlorine is much better at killing it.
