Thread: what is the good depth for the size of 16 x 26 in-ground ?
    We have a 16' X 26" in-ground pool and not sure what we want to do with the Depth of the pool. any suggestions?
    The family member Hight are from 5 feet to 5'9 feet.
    1: From low to deep
    2: Both side Low and Deep in the mid
    I am new and this is the first pool....pls help ...
    Thank you So much....
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: what is the good depth for the size of 16 x 26 in-ground
    Welcome to TFP!
    It depends on how you want to use it, because you will use it like you build it. If you want to play volley ball a lot, go with the "play" or "sport" option where it's just deep in the middle. This might be 3.5-4.0' on ends to 5.0-5.5' in the middle.
    Maybe you want a slide on one end, so make it deeper there. About 6-7' for that. If you want a diving board you need to go longer and deeper. At least 34 ft and 8.5-9.0' deep on one end.
    Essential Links:
    Hi Patrick,
    thank you for the reply. If I want to do it as for the lap pool. but the longer I can do is 26 due to the space. However if the 3.5 deep. is it ok to make a turn and with out hitting the leg in the low side ?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    If it were me, I would go ahead and make it 4'.
    Essential Links:
    HI
    So you mean from 4 feet's to 5 feet's ?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    4 on each end. 6 in the middle.
    Essential Links:
