Thread: Alkalinity question new TF 100 kit
    Northeast PA
    29
    Hi my pool is Ag 15ft round vinyl liner 36" deep so I guess 4000 gal.
    We just replaced the liner again last week. Test results today are:
    FC 5.5
    CC 1
    TC 6.5
    PH 7.2
    TA ?
    CYA 20
    CH 30
    I can't get the TA test to change from very dark pink. It changes at 11 drops and stays there. Also on the CH test when you add the R-0011L it says that red indicates calcium, but it changed to pink. Then I added the 3 drops of R-0012 to get the blue that gave me the CH result of 30.
    I added about 3 pounds of baking soda over the past 2 days. Thanks. Carolyn
    AG Pool 15 ft. round 4,000 gal. 100LB Hayward Sand Filter
    TF 100 Test Kit
    Carpe Diem!
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Alkalinity question new TF 100 kit
    Pm Duraleigh....there is an issue with some kits and the TA and CH test had a misprint....not sure.
    My TA test turns pink, not red, is that what you are meaning?
    BTW, you need to shock, you have a cc of 1 which is too high.
    Northeast PA
    29
    Yes, my TA test turns a very dark pink fuscia color it won't turn red. I'm scared to add any more baking soda until I know if this is normal for that test.
    TF 100 Test Kit
    Carpe Diem!
    Once the color starts to change, you keep adding drops until the color doesn't change any more. Don't count the last drop that didn't change the color. It doesn't really matter what the final color is, red pink fuscia.
    Northeast PA
    29
    Gee, thanks! If only that was stated somewhere on the test it would clear up a lot of confusion, not to mention adding more stuff to the pool. I kept trying to get the test to turn red. Thanks again, Carolyn
    TF 100 Test Kit
    Carpe Diem!
    Guest
    in the drop counting tests you are looking for a color change, not a specific shade of a color so when your TA test changes from a shade of green to a shade of red (pink or fushia also) and does not change anymore even though you had added an additional drop then the test is done. Don't count the drop that produced no further color change. Remember, one man's dark pink is another man's red.
