Results 1 to 9 of 9
Thread: Replacing a Hayward AquaRite Generator Cell
    mpride's Avatar
    May 2008
    Sugar Land Texas
    73
    I need to replace my chlorine generator but I need to verify the model number of the one I need to purchase. I have sent an email to Hayward but haven't heard back yet.
    My current one shows to be a t-cell-5 via the aqua plus control panel. The firmware revision on the controller is 3.00. Does anyone know what model number cell I need to purchase? If not, do you have any ideas about where I can get a definitive answer?
    Is the GLX-CELL-5 the replacement?
    Mark
    IG Gunite * White Plaster * 26'9" x 14' * 310sqft * 70' Perimeter * 9300 Gallons * 2 Main Drains
    2 Skimmers * 4 Jets * Aqua Plus Control System * Aqua Rite Salt System * C3025 Cartridge Filter
    Tristar 2HP 2 Speed Pump * H400K Heater * Phantom w/Booster Pump * ColorLogic
    38,284
    Re: Replacing a Hayward AquaRite Generator Cell
    How old is the setup? I think all the Aqua Plus units allow you to set the cell size, so technically you get get any of them.
    We recommend sizing the cell 1.5-3 times the size of your pool ... so at least the 15k cell (T-cell-3), but I might go with the 25k cell (T-cell-9).
    I do not see the T-cell-5 listed anymore, which I think was a 20k cell.
    mpride's Avatar
    May 2008
    Sugar Land Texas
    73
    My pool was built in 2009. According to the information I've seen online the t-cell-3 and t-cell-9 are not compatible with my controller because the firmware is too old. I'm not sure if thats all accurate or not.
    Mark
    38,284
    Hmmm ... the switch in software happened around 2008, so I guess it is possible you have an older controller. But, I keep seeing software numbers in the 1.X as the cutoff and you say you have SW 3.00? Although that is for the Aquarite ... so maybe the numbering is different for the AquaPlus / ProLogic units. I will keep looking.
    38,284
    Do you have an AquaRite or an AquaPlus? Assuming the latter, it does look like you need revision 4.1 or later to use the -3 or the -9
    What I am not clear on is whether your unit will work with either the -5 or the -15 ... I think this is the case and if you can still find the -5 (not listed by Hayward anymore) it should work.
    This seems to agree that you could use the -5 or the -15:
    aquarite-which-cell-to-purchase-t-cell-5-with-v1-4-t45272.html#p368712
    The -15 would need to be run on a lower setting, which should allow it to last longer ... depends on the price difference you see I suppose.
    mpride's Avatar
    May 2008
    Sugar Land Texas
    73
    Yeah, its the AquaPlus controller.
    Mark
    mpride's Avatar
    May 2008
    Sugar Land Texas
    73
    Ok. I replace my cell with a glx-cell-5. My old cell had been slowly going bad and reporting lower and lower salt levels even though the salt level was fine. I replaced the cell this past Friday evening. I checked the salt level and it's at 3300ppm which is very close to the previous optimum readings. I turned everything on and checked the controller and it had the following 3 errors:
    Chlorinator Off - High Salt/Amp
    Check System - High Salt/Amp
    Check System - Very Low Salt
    I'm a little confused by the errors. I thought I would let the system run for a few days and see if it normalized. I checked today and still have the same 3 errors. Is there something I need to reset on the controller? Is the cell bad? Am I nuts (probably but....)?
    Mark
    38,284
    I have no idea how you can have a low salt and high salt error at the same time.
    You can try hitting the "+" button while the error is displayed to see if it goes away.
    Are you able to set the cell size in the settings?
    mpride's Avatar
    May 2008
    Sugar Land Texas
    73
    Yeah. Just a bit confusing. I just tried your suggestion with no change. The cell is set to T-cell-5.
    Mark
