Results 1 to 11 of 11
Thread: Where do I buy polyquat 60?
    I just went to my local hardware store and they don't have polyquat 60 in any brand. I'm hoping to save time by asking on here. Is this only sold at pool stores or would Lowe's/Home depot carry it? THanks!
    27K gallon, IG vinyl pool, SD80 Sand Dollar sand filter-Michigan, 1hp pump
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,109
    Re: Where do I buy polyquat 60?
    I always buy mine from Amazon. Runs about $18 or so.
    38,520
    Ordering online seems like it can save a good chunk of $. I know Leslies around here sells it at something like double the price as online.
    I'm anxious to close my pool and was planning on doing it by the weekend. Being impatient, how important is using poly60 vs nothing.
    30,432
    It's really hard to say. Many don't use it at all. If you choose not to and you have to clean up an algae bloom that may take a week in the Spring, that impatience will seem silly.
    If you open up to a clear pool, however, you will congratulate yourself on the money you saved and satisfying your impatient nature.
    No one can predict the exact outcome. though. You'll have to make the call.
    38,520
    It is insurance if your FC drops too low over the winter ... you may or may not need it.
    What is the hurry to close? If your water already below 60 degrees?
    As of last night, pool was 62 degree with more cold nights in the forecast. The leaves are starting to fall and am just ready to be done with the pool for a while. Admittedly, both neighbors with inground pools closed last week, so that also has been feeling like I need to get moving.
    Jul 2013
    Swartz Creek, MI
    67
    You should be able to find some locally unless you're way off the beaten path. Any pool store should have it. Just don't make eye contact while you're in there.
    45ish year old, 16x32, 19,000, IG, Concrete/Fiberglass Hybrid in need of restoration
    Sand filter with 3/4 hp AO Smith pump. 1 skimmer, 1 main drain, 1 return
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    If you are a prime member, you can get free 2 day shipping from amazon. The current price is $17.99 + tax.
    http://www.amazon.com/Kem-Tek-311-6-60- ... olyquat+60
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I am of the mindset of why put something in the unless it is necessary? It's just one more chemical to swim around in and be exposed too. Might not be a big deal, but the less the better for me.
    Essential Links:
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    I agree that most do not need PolyQuat. I have many very large trees (mature tulip poplars ~100ft tall) that shed an enormous amount of leaves (enough to fill a dump truck) before my pool temp gets to the recommended closing level. I also have a loop-lock cover, so I need PolyQuat because I would rather spend a little to protect the water and close early than deal with the leaves.
    Karen
