Results 1 to 10 of 10
Thread: Help with first SLAM
    Sep 2013
    Orange, TX
    25
    Ok, need some advise.
    It rained over 5 inches over the weekend at my house. Tested yesterday with my K-2006 kit and got high CC so I started to SLAM.
    This morning my FC was 28.5 and CC was 15. Is it possible to have that much CC. Water looks clear and no algae to the naked eye. I added more liquid chlorine to bring FC up to 35 since my CYA is 90.
    I guess I just keep FC at SLAM level and keep checking, right?
    18,500 gunite/pebble plaster, Taylor K-2006 test kit, Jandy 2hp variable pump, cart. filter, ozone system, in-line-chlorinator(not in use), borates, Polaris 9400
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,042
    Re: Help with first SLAM
    Just out of curiosity, did you add anything besides liquid bleach? If you used any Monopersulfate "shock" it falsely reads as CC.
    There's also a very very very slim chance that the rain washed soil in that contains some bacteria that converts CYA into ammonia, which will create high CC readings and a huge appetite for bleach.
    22,551
    It's possible to have a CC of 15 ppm but rain shouldn't have done it. Does the rain run into your pool? It could have possibly have washed something into your pool from the surrounding area.
    Sep 2013
    Orange, TX
    25
    I have only added liquid bleach. I do have landscaping behind my weeping wall, but I did not notice any debris. Also, I have deck drains around the pool so no water drains into the pool.
    30,426
    There really is no point to test for CC's once you start the SLAM process. No harm in doing so but no real benefit.
    To complete the SLAM, you have to pass OCLT, so when you think you are to that point, just add the CC's test to your AM portion of the OCLT.
    Sep 2013
    Orange, TX
    25
    Ok thanks. While the SLAM is taking place do I need to adjust pH to proper levels?
    Sep 2013
    Orange, TX
    25
    Nevermind last question on pH. I read in pool school do adjust pH before you start since the ph test will be not accurate during SLAM.
    Sep 2013
    Orange, TX
    25
    Ok. I have 2 more questions.
    1. With FC in mid 30's during SLAM, is any danger of damaging plaster?
    2. After SLAM is complete how do I get the FC lower to normal levels?
    Richard320's Avatar
    Jan 2010
    19,042
    Quote Originally Posted by kdiamond
    1) No.
    2) Stop adding bleach and it will go down all by itself in a couple days.
    It is safe to swim up to shock level for your CYA, so as soon as FC dips a little, you can use your sparkling pool.
    Sep 2013
    Orange, TX
    25
    ok. Thanks for your help.
