Results 1 to 9 of 9
Thread: Best, most cost effective floating cover support?
    Jul 2013
    NH
    86
    Expecting water to freeze solid in NH. I'm thinking farm tractor tire inner tubes but haven't checked the price.
    What say you folks?
    Mike
    18' Sharkline Oceanic
    Gorilla Pad
    Foam cove
    Confer 7200 ladder
    TF-100
    Use DE for your filter? DO NOT use anything but POOL GRADE DE!
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Best, most cost effective floating cover support?
    I'd look around,might get that tractor inner tube for free. Any inner tube is better than those pillows.
    Jeff
    Aug 2009
    SW Wisconsin
    518
    You are SPOT ON! I've tried every "pool pillow" out there, and they are don't last a winter. I went to old farm tire inner tubes, and they just keep going and going and going. I tie 4 of them together in sort of a "4 square" pattern to create one large float for the center of the pool.
    33' x 52" Swim and Play Inc. PARAGON AGP. Hayward H200 Heater. Hayward Power-Flo LX 1.5hp pump. Sta-Rite Cristal Flo T-210WF Sand Filter. Stenner 45M5 chlorine pump
    Jul 2013
    NH
    86
    Any idea how much they go for? I'm thinking about tying 2 together but stacked on top of each other, then tied off to the pool rails.
    Mike
    Gorilla Pad
    Foam cove
    Confer 7200 ladder
    TF-100
    Jun 2012
    western NY
    1,559
    Quote Originally Posted by NHfloater
    We used to do it that way (my brother and I) now we use plastic 55 gallon drums. I was able to get one from work (knew what was in it). A local hardware store also sells reconditioned drums around here.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    If you have a TSC (tractor supply) nearby try them.
    Jeff
    Jun 2013
    North Shore Massachusetts
    20
    I couldn' agree with you more. Those large inflatable pool pillows are complete junk. I never got more than a month or two out of them before they deflated leaving my mesh winter cover submerged under 6" of water. I switched over to three Intex River Run II Rafts six years ago for equilizer pillows for my 24' above ground pool. All three rafts are still currently in use and function perfectly. What's great about the rafts is they have high-back pillows which do a fantastic job keeping the cover suspended high off the water surface. Also, the threaded quick inflate/deflate valve is invaluable. I can completely deflate each raft in less than a minute without having to wrestle and twist the raft to get ALL the air out.
    2002 24' Aluminium Sharkline Coronado 52" AG Pool, Hayward EC50 DE Filter, Hayward 1HP Power-Flo LX Pump, TF-100 Test Kit
    reindeerboy's Avatar
    May 2008
    Jamestown, ND
    519
    I go to an implement dealership to get used inner tubes that they done want and then put a patch on it and use them. I need to do it again and plan to go to a couple larger tires, tied together and then let it buck. Probably next weekend I plan to close and then run around to find what I want. Inner tubes work the best as you can take out the core and the air is easy for quick storage then.
    Chad R.
    POOL SIZE: 16 x 32' Vinyl lined pool. 22,000 gallons. 8' deep. 2009 Hayward 1.5 HP Super Pump. Hayward S310S 30" 500 lb Sand filter. 1 skimmer and 2 returns. Solar Blanket.
    Pics of my pool: http://s307.photobucket.com/albums/nn312/reindeerboy/
    Jul 2013
    NH
    86
    Thanks for the replies, guys. There aren't any tractor service places locally to find used ones but there's a TSC in the next town over.
    Mike
    Gorilla Pad
    Foam cove
    Confer 7200 ladder
    TF-100
