Results 1 to 7 of 7
Thread: Question about lowering the PH and Alkalinity for winter?
    Need some help with getting the PH and Alkalinity to correct levels before closing. My levels are: FC: 3.06
    Cyanurica Acid: 99ppm
    PH: 8.15
    Alkalinity: 171ppm
    Any suggestions on what I can use to lower the PH and Alkalinity to in range levels? Thanks!!
    Re: Question about lowering the PH and Alkalinity for winter
    pool-school/lowering%20total%20alkalinity
    Also, your FC is too low for your CYA.
    pool-school/chlorine_cya_chart_shock
    What are you using to measure your chemistry levels?
    Support the site
    I work at a waste water plant for the local town, we also check our pool water from the town pool, so I decided to bring my water in to check it also, we use a Thermo Scientific AQUAfast AQ4000 digital meter. The meter uses the tablet type check system. Drop a tablet in, crush it up and check your sample. Maybe meter is not checking my sample correct?
    I was just curious, as the numbers seemed to be very specific. I don't have any reason to question them.
    Support the site
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by KB18fan
    That's interesting. What all do you run on the town pool, and what else do you run on this machine for the WW plant just curious?
    Essential Links:
    Nothing on the Waste Water side, we can run Total Chlorine, Free Chlorine, Alkalinity, Cyanurica Acid, & P.H. on the Aquafast machine. Their is a lot of different tests that we could run, if we had the check tablets. We use a HACH Colorimeter to check our Total Chlorine in our Effluent water that we discharge. We still treat our waste water with Chlorine and we use Sulfur Dioxide to take so much of the Chlorine out before it hits the stream we discharge to. If we discharge to much chlorine into the stream, we will end up killing the fish.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    OK, I am very familiar with the HACH equipment, just never seen the Aquafast machine. Have you done any reading on pool chems in Pool School, and have you made any adjustments yet? This is really pretty simple stuff and even though you have access to that equipment, I would still recommend one of the test kits here.
    I could run everything and more (save Chlorine) by taking a sample to work, but I would rather do it on my patio with a cup of coffee or adult beverage to accompany the testing.
    Essential Links:
