Thread: Closing a Salt Water Pool
    I have bee told for Salt Water Pools to add a Scale Free Product over the winter to prevent scale. Does that even work? I had a scale problem last year so would like to avoid it if I can but I will be monitoring the pool's ph level throughout the winter....my calcium level is over 400 so concerned...did some draining this summer to lower it but still at about 450.....
    38,248
    Re: Closing a Salt Water Pool
    Actually, all other levels being equal, the higher level of salt in a SWG pool actually REDUCES the likelihood of calcium scaling. If you are going to be monitoring the pH, then there should be no need for a scale free product.
    Interesting....I noticed that in the pool calculator but what I am talking about is not the salt level of my pool but the calcium hardness level...isn't there a difference?
    38,248
    It is not only the CH that leads to calcium scaling ... the other parameters play into it as you see in the calculator via the CSI.
    You CH is really not that high we have members with quadruple digits.
    I was simply saying that having the extra salt actually lower the CSI and thus the liklihood of scaling ... which seems to be opposite what "you have been told"
