Thread: Closing AG pool in S.Cali for the first time
    Apr 2013
    South California
    69
    Questions:
    1. Do I need to close the pool in South California? yes/no so how to?
    or
    2. Do I need to drain it completely and put the pool away for next year?
    What is the best approach?
    Sorry for the newbie questions because I am a newbie .
    Summer Escape 4k gal-AG
    Intex sand filter 1600 GPH
    Intex SWG model 54601
    Taylor K2006 kit & Taylor Salt Water Test Kit K-1766
    Installed 4/29/13
    38,547
    Re: Closing AG pool in S.Cali for the first time
    Unless you are on a mountain ... I do not think there is any reason to "close" a pool in So Cal. Do you get and stay below freezing?
    Likely all you need to do is cut your pump run time back and continue to maintain adequate FC in the water and it should stay clear all winter. The FC consumption will be greatly reduced from the summer, so it is not too difficult to maintain.
    If the temp is going to drop below freezing (like it does here on occasion), then you just run the pump overnight to prevent the water from freezing in your pipes/equipment.
    EDIT: Although I see you have a small pool. So you could just drain it and take it down and set it back up in the spring.
