Thread: Main pump sprung a leak
    First, the advice on this site has saved me hundreds of dollars. Thank you to all you experts. I am not one of you, but you've gotten my chems in balance and even better, you get me to UNDERSTAND why things happen.
    Today, I realized my main pump Jandy 2 hp Stealth was squirting high pressure water out the side of the junction between the motor and the pump body. The exploded view diagram makes it look like it's the gasket between the plate on which the motor is mounted and the pump. Is it really that simple? Or are there seals or o-rings internally that also need replacing?
    I'm trying to decide whether to call my pool guy or do it myself. I'm very handy (replaced salt system and did salt cell plumbing, replaced o-rings, replaced DE filters, etc.), and if it's just replacing a gasket, I'm probably fine. But if it's more internal stuff that should be replaced, I may opt to hire someone. Thoughts?
    30,000 gal salt with spa; built 2006; Jandy 2 hp single speed Stealth; 48 sf Pentair DE filter; Pentair 4 wheel cleaner; Jandy 1400 SWG and 1400PLC salt cell. New filter grids, cleaner pump.
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Main pump sprung a leak
    If water is squirting out, it's probably an o-ring. Can you post a picture? Search the pumping station forum....someone had a very similar problem back in the beginning of the summer. Given what you've described about your abilities, it sounds like you can handle it.
