Results 1 to 9 of 9
Thread: Tight Winter cover ?...
    Jul 2013
    Chicago IL
    83
    Just closed my 15ft round pool.. Bought winter cover from American Sales . Lowered the water about 6in below skimmer.. Just seems like with snow and water its going to be pulling tight on the cover, I put some water on it to keep it down... Heres the pics::
    15ft Round, Above Ground , Rheem 106K Heater , Black Diamond 90 Cartridge Filter, Pool Frog(disconnected) ,TF-100, City of Chicagos finest H20
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Tight Winter cover ?...
    That cover looks too small for your pool. Is there any slack below the blue wrap? Is it a solid cover or is it a mesh cover?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    You could put a couple of inner tubes under the cover to support the weight of snow and water, but you'll have to take the blue wrap off and redo it.
    Jeff
    Jul 2013
    Chicago IL
    83
    The cover wraps over about a foot of slack around the outside....
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    That slack should be up in the pool.
    Jul 2013
    Chicago IL
    83
    Heres the pics:: ... ????? *** , it seems tight
    Jul 2013
    Chicago IL
    83
    I cant go any higher with the slack on the outside because the top of the rail caps are on an angle /..... should i get an 18ft???.. i rather change it now than have problems when its 20degrees out
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    With your larger top rails that cover is too small. I would go for a cover that is 6' larger diameter than your pool.
    Jul 2013
    Chicago IL
    83
    Yea, thats what i thought ... Thank you
