Thread: Question about pump noise and high filter pressure
    I've been hearing kind of a whining sound coming from my pump motor (Jandy Stealth 1.5hp). Initially, I thought it was the motor bearings beginning to fail. However, my filter pressure (Jandy CV340 cartridge), normally about 10psi is up to about 18psi. I cleaned the cartridges and replaced them, but the pressure is still 18psi. I noticed the pump is much more quiet at 0 pressure while it's priming, then the whining gets louder. Thinking the cartridges may need to be replaced, I removed them from the filter and started the pump. Still at 18psi. I did check the pump with a stethoscope and the motor housing is pretty quiet, however, the pump portion whines loud. I am assuming I have a blockage somewhere and when the pressure gets high, the impeller is making the noise trying to move the water. How can I determine where the problem lies?
    Daron
    20k gallon gunite pool with a Jandy CV340 cartridge filter, Jandy Stealth 1.5hp single speed pump, T15 Salt Cell, Polaris 280 cleaner with booster pump.
    20k gal Gunite, diamond brite plaster, Jandy 340 cartridge filter, T-Cell 15 SWG, Jandy Stealth 1.5hp single speed pump, Polaris 280
    38,246
    Re: Question about pump noise and high filter pressure
    Does the gauge read 0 when the pump is off?
    If the gauge is fine, then sounds like you have a blockage (or closed valve) after the filter. Do you have multiple return paths to the pool?
    Yes, as soon as I turn the pump off, the gauge reads 0. I have two return paths. One for the 5 pool returns and one that feeds my deck jets. I can't even imagine how they would get blocked. Just had another thought, I guess I need to check my salt cell for restriction.
