Thread: No power to pool equipment
    partypond's Avatar
    Jul 2008
    Frisco, Texas
    89
    As f yesterday afternoon I have no power going to my pool equipement. I have the Jandy Aqualink RS PDA remote and it will turn on but not connect to the power center and there are no light on or any response from anything in the power box. l have checked all connections, breakers, GFCI plus etc... There is power going to the plug/switch right below the box this is what the board look like....
    http://www.poolsupplyworld.com/Jandy...FSho7AodxTIADQ
    Does anyone know if there is a fuse or reset for the board?
    Any help in diagnosing the problem would be great. Not sure what other info you would need so ask questions if that helps.
    Thank you
    36x16 gunite, 14,500 gallons, Jandy 2.0hp VS Epump, Jandy CL460 filter, Automatic chlorinator, Jandy Legacy 400K BTU Heater, Polaris 1.5HP spa blower, 2 Colorlogic pools lights and 1 Colorlogic spa light, Polaris 3/4HP booster pump, Polaris 280 cleaner, Jandy PS4 with PDA, QuartzScapes Montego Bay plaster, OK flagstone coping, spray deck (aggregate effect) - completed 3/2011
    partypond's Avatar
    Jul 2008
    Frisco, Texas
    89
    Re: No power to pool equipment
    I took apart the power center and found a fuse on the computer board. Replaced the fuse and all is well now. Not sure why it blew but at least we have power now!!
