Thread: Expandable (freeze) plugs vs. threaded plugs
    My return lines on my pool are threaded, however I always have had problems removing the threaded plugs when I open the pool in the spring. In fact, this past spring, when trying to remove the plug from the outlet connector on the side of the pool, the outlet connector loosened instead, causing a leak. Instead, can I use the expandable (freeze) style plugs on these threaded outlet connectors? It seems that these would be easier to remove, and eliminate the problem I had.
    Mark
    Re: Expandable (freeze) plugs vs. threaded plugs
    I would say yes, but, you should make sure that the expansion plugs have a smooth inner pipe surface to seal on. This means the plug should be longer than the female threads. If not, expansion plugs won't seal well on threads, and will tend to slowly leak, unless you can get a good seal on the front face, which would require using a plug with a shoulder, and pushing it in as hard as you can while tightening the expansion plug. The trick to making the threaded plugs easier to remove is Teflon thread sealing tape. Wrap clockwise so that it's in the same direction as you turn it to thread it in. Otherwise, it will tend to come off as the plug is turned in, but don't overtighten it, as plastic flows over time and will tend to set in place due.
    21,000 gallon, IG Fiberglass, Hayward S-244T High Rate Sand filter, Hayward 1 HP pump
    May 2013
    Long Island NY
    419
    You can get plumbers grease at home depot to put on the threads and you will never have that problem with stuck plugs again.
    19,000 gal - Vinyl IG - Sand filter -1.5hp. - Taylor k 2006 - Loop Loc cover
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    422
    Use pool grade silicone or Magic Lube on the threaded plugs + get and use the Hayward tool for installing and removing the plugs. Flat plastic blade that fits perfectly in the groves. Tool is like $7.
    Threaded in my opinion are better as they will not pop out and they seal well.
    Also make sure you have O rings on the plugs.
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
