Results 1 to 7 of 7
Thread: What can I do about leafs in Spa
    Hello All,
    I have this Spa that overflows into a pool. Every morning before I go to work, I have clean the leaves off of the grating/grill covering the overflow drain (see picture). If I don't, the spa overflows.
    [attachment=0:1sgs9r28]Woodberg-OverflowDrain.jpg[/attachment:1sgs9r28]
    So far, this is what I can see can be done
    1. Clean leaves daily (burdensome)
    2. But pool leaf net (I am having trouble finding one for 10 feet round spa. The smallest I can find is 12 feet. They don't look good)
    3. Solar powered skimmer (too expensive at more han $400)
    Does anybody have any suggestions? Thank you all
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: What can I do about leafs in Spa
    A diverter that routes water from below the water line up to the overflow (like an S-shape). That way, leaves will remain above the opening of the diverter. The water in the spa will simply rise in the diverter and overflow as needed. Of course, I don't know where you could get something like this.
    Thanks for the advice. Sounds like a great idea and has to be out there. I'm a looking...
    This overflow grate, it flows into the pool?
    Can you just remove the grate and let the leaves go into the pool and pool skimmer?
    If not, is the water flowing into the spa coming through a return (I know that's a stupid question, obviously water is flowing into the spa or it wouldn't overflow, just wanted to make sure)? Why not something like a Poolskim
    http://www.poolskim.com/description.htm
    Blaine
    50' x 22' 27k gal shotcrete freeform, 2hp 2 sp Pentair Whisperflo, Pool Pilot RC-52 SWCG, Pentair TR 100 sand filter, Prowler 820 robot, Florida Sunseeker LED lights.
    My pool build:
    osage-hills-pool-build-t50526.html
    bpricedo
    Right? Would would happen if I just took off the grate. I guess my concern is that the leaves would enentually clog up the overflow line from the spa to the pool. But I don't know, what do you think?
    I just looked at your suggestion of poolskim---seems like it might work! I also saw a competitor called Pool Devil. It is cheaper but has many bad reviews regarding poor quality. I went ahead and ordered the poolskim. I'll let you know how it works.
    Thanks for the lead.
    I am not sure what type of overflow you have. What is the overflow line? If there is a chance it could get plugged by debris, then I wouldn't take the grate off.
    Blaine
    My pool build:
    Here's the update. Poolskim came and installed. One things I realized is that the return connection where you would connect it is also a whirlpool/spa jet. Does this mean I can't turn on the whirlpool, since one of the jets is covered by poolskim? I turn on the pool motor and can see water flowing throught the pool skim. Nothing really happening. The instructions say to cover up some of the other returns, but if I do that, then I am covering up all the whirlpool jets. Maybe I don't have it installed correctly. I am going to look again and see if I can get it to work. To be continued...
