Thread: white flakey substance in Slat Water pool
    There is a white crystal-like substance on the bottom of the pool near the return outlets. Who can help?
    Latest test results fro Leslie's
    Free Chlor 8.0
    Total Chlor 8.0
    Salt 3400
    Cyanuric Acid 60
    Total Alkalinity 130 (it's taken 6 weeks to get it down from 280 by adding 24oz. of Muriatic Acid daily)
    pH 8.0
    Acid Demand 2
    Copper 0
    Iron 0
    Phosphates below 100ppb.
    Any help would be sincerely appreciated.
    Keith
    Th
    Santa Ana, CA. 92707
    15K gal, saltwater w/spa, IG, plaster
    3HP Intelliflo VS-3050 pump, 60 sqft DE 150gpm, solar heat & Hayward H400IDL2
    30,424
    Re: white flakey substance in Slat Water pool
    Got a pic?
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    It is likely that your SWG is causing calcium to precipitate out of your water. There are two issues:
    1. What is your CH level?
    2. You need to get your pH down around 7.4ish and keep it there. You don't want it to get to 8 at any point.
    Did you get a test kit yet? It's much easier to maintain levels with your own kit.
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    Oct 2012
    209
    What is your salt level?
    24' round above ground, 13500 gallons, vinyl liner, 18" Sand Filter
    Just cleaned up the substance so I can post a picture in a few days. I've been a pool owner for 6 weeks so I'm not familiar with the terms. I assume the SWG is salt water generator but I don't know what you mean by CH level. I assume it would be chlorine but I gave you that information int he original post. Salt level is in the original post too, 3400. I do have a test kit but don't really trust my ability to use it. I measure the alkalinity daily and it varies between 160 to 180 but haven't been able to get it lower. I simply don't know how to get the pH down!
    Here's the link to reducing your TA
    pool-school/lowering%20total%20alkalinity
    The flakes are likely to be calcium carbonate. You can confirm by putting a drop of acid on the flakes. If they fizz and bubble, then it's likely to be calcium carbonate.
    CH means calcium Hardness.
    You're probably going to have to get your TA down to about 60 ppm before the pH stays down at a good level. If you have new plaster and/or heated water, that would make it more difficult to keep the pH down.
    Support the site
