Thread: Concrete and Elastomeric movement and crack
    Sep 2013
    DFW Metroplex
    119
    My pool shows crack in concrete joints and in few areas elastomeric material is peeling off, what can I use to fix this? I see two different materials
    1. Yellow arrow represent concrete filling
    2. Red arrow represent elastomeric filling - I am planning to use SikaFlex -SL for this
    Can I use SikaFlex - SL from Homedepot for both 1 and 2 ?
    13K gal, IG, Gunite pool with raised spa water spill over to pool, built on 2005
    1.5 HP Hayward MaxFlo VS - June 2014
    DE Filter Model # DE6020
    Added Borates on Jun 2014
    30,432
    Re: Concrete and Elastomeric movement and crack
    Yes. It wont match existing grout. Clean out all the old grout that you can and tape both sides of the joint so you don't smear the caulk onto the stone.
    Sep 2013
    DFW Metroplex
    119
    Thanks! I am going to try it out on coming weekend
    Sep 2013
    DFW Metroplex
    119
    I am not sure if I am violating this forum rules by asking this question, but want to check, do you guys recommend any pool repair guys from Dallas area? I am still learning how to operate my pool properly. I tried one from Angies list, had a bad experience.
    Things I want to learn:
    1. How to do backwah.
    2. Value operations.
    3. Hard time keeping Kripy Krawly moving, today, i lift the whole equipment to see what's going on, now its totally stopped moving .
    4. Pool heater operatin. First time powered on yesterday, but after 15 minutes I don't see any water temperature change.
    22,553
    You're not violating any rules by asking, but the forum doesn't make recommendations. If a member wants to personally make a recommendation to you, that's fine, just don't be surprised if there isn't one.
    Having said that, using a pool guy to learn how to set up and run the equipment may be a good choice for you. That way you get hands on instruction. We're not opposed to service guys or pool stores in general, we're just opposed to what they do to a majority of pools and pool owners.
