Thread: leaky bulkhead fittings
    rmozer's Avatar
    Oct 2012
    Remsenburg/Speonk, NY
    26
    I have an old Hayward S200 sand filter and the bulkhead fittings started leaking this summer after I installed a new Hayward variable speed pump. Not sure if it's coincidental, or the new pump has put more pressure on the old boy than he's used to.
    How do you remove the bulkhead fittings? Do they unscrew from the inside of the filter? Because the fittings on the outside are hex head, and are about 3", I'm hoping they will come off from the inside using a smaller wrench. I don't have a wrench that's as big as 3" unless I use a pipe wrench, which will bugger up the plastic fittings. Yes/No?
    Thanks.
    Bob
    22,000 gallons
    new Hayward sand filter
    IG
    vinyl
    2 hp Variable speed pump; 20 gpm/ft2 filtration rate; 62 gpm design flow rate
    May 2011
    Long Grove, IL
    117
    Re: leaky bulkhead fittings
    Bob,
    Here is a link to a socket that I bought to replace the bulkhead fitting in my PacFab filter. It should also work for you.
    http://www.amazon.com/gp/product/B00063 ... 00_details
    Here is a link to an old thread about replacing the bulkhead connectors in a Triton filter but the process should essentially be the same although I have never seen a Hayward filter close up.
    filter-repair-tr-100-t28933.html
    Regards,
    Jay
    Jay
    28,000 gal in-ground hybrid pool with PacFab Superflow 100 sand filter witn VitroClean media, Intelliflo VS pump, Stenner chlorine pump, Raypak R336A Millivolt Natural Gas Pool Heater
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    If you type "Hayward S200 Sand Filter" into Google, the first hit is a pdf of the of a Hayward S200 manual. It has a parts diagram which seems to show o-rings at the bulkhead fittings and it looks like the fittings must be removed from the outside. If you wrap a couple of thicknesses of cloth rag around the hex surfaces you can avoid damaging the plastic surfaces with a pipe wrench. Otherwise there's always Harbor Freight for a cheap, humongo adjustable wrench.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    rmozer's Avatar
    Oct 2012
    26
    Thanks all for your help. I will try the pipe wench approach.
    22,000 gallons
    IG
    vinyl
