Results 1 to 7 of 7
Thread: Swap shut off valves?
    Sep 2012
    Noblesville, IN
    83
    I am thinking ahead to when I try to close my pool by myself for the first time in a few weeks. The picture below shows the three pipes coming from my two skimmers and the main drain. I need to air lock the main drain but can blow all the water out of the skimmer lines. The far left valve is for the main drain but the shut off lets water through when it's closed. The other two for the skimmers work as intended...of course . Since the main drain valve is the one I need the air lock on, can I swap the innards of one of the other shut off valves with the not quite functioning one in the main drain instead of cutting pipe?
    32K in ground vinyl pool installed in the early 1990s
    1.5 HP Centurion pump installed in the September of 2012, replaced under warranty in August of 2013
    2.6 SF Hayward sand filter - age unknown but looks pretty new
    Jandy AE-TI heat pump - age unknown but looks new and works great
    Caretaker in-floor cleaning system - works, but not well....on my list of things to work on.
    Aqua-rite SWG - new in about 2006, T-15 cell replaced in summer of 2012
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Swap shut off valves?
    Undo the unions of all 3 valves and remove the top plumbing assembly away from the valves coming out of the ground. Simply blow the main drain directly through the valve and use a rubber compression plug to seal the maindrain. Naturally you have to do it fast but if you try it a few times in a row you will get good at blowing and quickly jamming a rubber plug into the hole. Once the main drain is plugged put a solution of dish soap and water on the plug and look for bubbles as sometimes the stems leak on those plugs or it may even leak around the edge. If you don't see any bubbles secure the rubber plug from popping out with duct tape or electrical tape to prevent the plug from slowly popping out of the winter.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    May 2013
    Cyprus
    159
    Hi
    You could get a plastic bag of sand and cover the main drain I know this works.
    Living in Cyprus
    Still enjoying life
    Sep 2012
    Noblesville, IN
    83
    Thanks for the ideas! I thought about using a plug on the shut off valve but I'm not sure if the guts of the valve will interfere with the plug. I suppose the only way to find out is to do it and see what happens.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    It won't interfere you just may need to take the guts out first. it will probably be a #8 plug that goes deep into the body of the valve.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Those valves are garbage. For the future, I would consider replacing them with some never lube valves.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Sep 2012
    Noblesville, IN
    83
    Well, I've decided to use a combination of everyone's advice. I am going to remove the upper portion of the plumbing, cut out the bad shut off valve and install a compression plug on the stub end. The other two valves go to skimmers that I can get all the water out of so I'm not worried about the upper plumbing....not to mention the shut off valves for those actually work.
    On a side note, as far as I can tell, the shut off valves are above the water line. When I remove the upper plumbing, water runs up and out of the main drain pipe. Not a ton, but it just keeps streaming out until I put the pmumbing back together. The two skimmer lines don't do that. What am I missing? Does this have something to do with a hydrostatic relief valve I may, or may not have?
