Thread: Variable speed only pump
    Jul 2013
    Austin, TX
    7
    We are looking at a new build. 534 sq ft (max length and width 28' x 21') depth varying from 4- 5.5'. Chlorine. It will have a spa as well as 3 water sheers and a 280 polaris. Pentair Quad cartridge filter.
    A 2.5 hp VS Pentair pump has been proposed coupled with a Pentair Easytouch control center to work ALL features. Does this seem reasonable or should we split off each system with its own pump?
    19k gallon pool with attached spa, in ground, pentair VS pump, Quad DE filter, Pebble Sheen plaster, built 3/2014
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Variable speed only pump
    Sometimes a single pump can be used if the plumbing system is designed properly but unfortunately in many cases, PBs don't have a clue. But to see if this might be possible in your situation, we need a lot more details about your setup.
    Pump model #
    Pipe diameter, run lengths and # of runs to each feature/port/etc.
    Number of spa jets and flow rate requirement per jet.
    Flow rate requirements for the sheers
    Mark
