Thread: Hayward Colorlogic LED pool lights
    Aug 2013
    Richmond, VA
    4
    Newbie here! Pool is underway & I'm considering Hayward LED lights. looking at Amazons reviews, they seem to develop leaks and short out w/ no way to fix it. - just buy a new one to the tune of $400! Any input from TFP members on their luck w/ these lights? Thanks for your help. El Syd
    16'x30' IG pool w/ 9'x16' tanning shelf, Plaster w/ color quartz finish, 12,500 gal
    1-1/2hp, 2 speed pump, 30" sand filter, 2 therapy jets w/ 1-1/2hp booster pump
    Automatic Pool Cover, Auto Fill, SWG w/Hayward Sense & Dispense & remote controller,
    heat pump w/ chiller, TF-100
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Hayward Colorlogic LED pool lights
    Welcome to TFP!
    I know this is an older post and no one answered it, but wanted to encourage you to continue to post and ask questions. Not every question gets an answer, but we should have at least welcomed you to the forum.
    I have no experience with Hayward lights... but I chose Pentair. Put in 3-5g lights, 3 led bubblers and one glo brite. The glo brite was dead on arrival... one bubbler failed after two months with a brown spot inside it where I am guessing something burned... may be from a seal failure. I still like the Pentair equipment... but am hoping I am done with the failures. Id just recommend that you use same brand for all lights so your colors match.
    32K gal, gunite, French Gray DB, IntelliFlo VF, IntelliFlo, WhisperFlo, Quad DE 100 filter, IntelliTouch, IC-60 SWG, IntelliChem, Dolphin M5
