Results 1 to 13 of 13
Thread: Salt in Liquid Chlorine?
    Aug 2013
    Chandler, AZ
    121
    So I went to the pool store to pick up some stabilizer and of course they want to test your water. I said I was OK, but thanks anyways. I then wanted to know their price on liquid chlorine and he was saying that he wasn't a fan of it... because it had salt in it.
    I am new to all of this.................
    ..... but I've never heard that liquid chlorine had salt in it. If it does, then it must be a negligible amount.
    So all I could think about was... of course he doesn't like liquid chlorine. He likes tablets... because tablets generally throw other things off like pH or CH... which in turn causes you to come back and buy more of his products. All of this of course was after he tested someone's water in front of me, of course telling them that their water was about half a day away from being a Florida Everglade Swamp. For granted, it may have been... since their chlorine was zero.
    Anyways, am I missing something on the chemistry lesson here, does liquid chlorine have salt in it... and if so... how much?
    12.4k IGP 27'x14'x4.5', Pebbletec, Pentair EasyTouch, Pentair Intelliflo VS, Pentair IC40, Pentair Quad DE 80
    Jul 2013
    South tx
    10
    Re: Salt in Liquid Chlorine?
    bleach = sodium hypochlorite
    so yes has salt, but not enough to worry about
    12000g outdoor, inground gunite, pebbletec. Cartridge filter. 2.0 HP Jandy pump, taylor test kit
    399,000 BTU Raypak LPG Heater, stenner pump
    Mar 2007
    San Rafael, CA USA
    12,082
    Chlorinating liquid and bleach have salt in them because of the Chlor-Alkali process that makes the chlorine. Electrolysis similar to what is done in a saltwater chlorine generator produces chlorine gas (except that this is extracted as a gas and not just dissolved in water). This is then combined with a solution of sodium hydroxide that is also produced from the electrolysis. So you mix them and get:
    Cl2(g) + NaOH ---> NaOCl + NaCl
    Chlorine Gas + Sodium Hydroxide ---> Sodium Hypochlorite + Sodium Chloride
    For every 10 ppm Free Chlorine (FC) in chlorinating liquid or bleach, there is also around 8-9 ppm salt. When the chlorine gets used/consumed, there is another 8-9 ppm salt for a total of 17 ppm salt.
    ALL sources of chlorine result in salt, but chlorinating liquid and bleach (as well as lithium hypochlorite) add additional salt when you add the chlorine. Of course, other sources of chlorine add other things than salt. Cal-Hypo adds calcium increasing Calcium Hardness (CH) while stabilized chlorine (Trichlor and Dichlor) add Cyanuric Acid (CYA). The CH and CYA that are added are much more problematic than the salt that is added from chlorinating liquid or bleach.
    Aug 2013
    Chandler, AZ
    121
    Chem geek I was just writing up how NaClO when mixed in water would yeild Cl and Na (and others)... but not directly NaCl. I am guessing that once the Cl is used that it recombines to make NaCl... which is how the whole SWG system loop runs in a way.
    In either case... I think my point was that the guy is shunning liquid chlorine because of a negligible amount of salt... in favor of tablets that spike CYA and CH which keeps you in his store.
    Donldson's Avatar
    NW Ohio
    2,892
    Quote Originally Posted by chem geek
    To this I will only add that salt doesn't become a problem until it gets in to the several thousand ppm range. CH can become a problem in the several hundred range, and CYA starts to become a problem when it rises over 50 (for non-SWG pools). I think I will stick with liquid myself, far less draining involved.
    If you continue to frequent that pool store, be sure to take everything with a grain of salt. Um, pun not intended
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    30,415
    Jeetyet's Avatar
    Jul 2012
    Florida Panhandle
    200
    I bet if you asked about Salt Walter Chlorine Generators he'd have been a big ole fan of salt in the water!
    "The early bird might get the worm, but its the second mouse that gets the cheese." ~ W. Rian Adams
    Relative's IG Vinyl | 16x32 | ~18,600 gals | Hayward 3/4hp Pump | Hayward S244T Filter | Pentair Model 300 Chlorinator (not used) | Polaris 180
    Aug 2013
    Chandler, AZ
    121
    Oh I forgot to mention, with the people before me he was fanning the idea of mandatory draining of pools every 2 years - "that is just the way it is."
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by peacefulkancer
    He is right. When you use Dichlor/Trichlor as a sole or major source of Chlorine all the time you'll have to drain to get your Cya back down to proper levels.
    Essential Links:
    Aug 2013
    Chandler, AZ
    121
    Quote Originally Posted by Brushpup
    Yep, exactly.
    Nov 2013
    Houston, Texas
    27
    Dumping the pool every two years would have been a deal for me back when I used Trichlor. I was dumping about a quarter of the water every month just to keep the CYA levels around 60. Lower than that was impossible. I was spending as much on water then as I am on liquid chlorine now. Then there was all the stuff the pool store sold me on top of the tablets to keep algae from exploding. PhosFree, algae inhibitors, algae killers, etc. The pink bacteria was especially annoying and hard to get rid of without regular shocking. On top of that, tons of acid, alkalinity up, and calcium. Now all I mostly buy is a little acid and liquid chlorine from Lowes, Depot, or Warehouse Pool Supply and my pool looks better than any other time in it's 11-year history. I use a Liquidator which I installed with no drilling off a Tee from my old tablet chlorinator and my pump drain. I also added twenty mule team borax to 50 ppm borate levels. I keep my CYA at around 20-30ppm by adding a few tablets to the old chlorinator after a back flush. I also add a little calcium to keep levels above 250ppm.
    Mar 2007
    San Rafael, CA USA
    12,082
    Welcome to TFP!
    Glad to hear The Liquidator and chlorinating liquid are working out well for you.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Yes indeed, good to hear it's working for you. Kudos!
    Essential Links:
