Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: watt
    Jul 2012
    Whidbey Island, WA
    397
    watt
    Hi
    How can I determine watts of my pump? Is WhisperFlo WFE4.
    I read some TFP postings but still confused.
    Called Pentair. Said they do not know. I should measure volts and amps and multiply.
    IG under fir trees and one cherry surrounded by grass built in 1979, 30k, plaster, old Sta-Rite HRPB30, 4.9 sq.ft, 20 GPM/sq.ft., but with new glass, new (in 2012) 1 HP WhisperFlo one speed, new (in 2013) Rainbow tab chlorinator attached at the top, old Maxi-Flo Heat Exchanger MF-260, Burnham V7 oil heater 245 MBH, new (in 2012) Compool to Easytouch, Taylor K-2005 and TF-100.
    22,548
    Re: watt
    The best way to do it is to actually measure the volts and amps and use that to figure it out. If you use the nameplate numbers you're not getting the actual operating numbers.
    Sep 2013
    IL/WI border USA
    5
    Re: watt
    As an electrical engineer, I have to jump in here. If you are wondering how much it costs to run the pump, then simply multiplying voltage and current will give you a misleading answer. A typical electric motor has a relatively poor power factor (maybe somewhere between 0.6 and 0.8), and therefore the apparent power (V*I) will be rather larger than the real power (V*I*PF). The electric company only charges you for the real power you use. There are some losses in the wires between the electric meter and the load (in this case the pump motor), and having extra current there can add to the real power consumed (because those loses are resistive) - but that would be really small for a typical pool pump.
    To really find out the power consumption, you need a watt meter. If you don't have that, then if you have an oscilloscope, you can calculate the power factor using the phase difference between the voltage and current curves. But I'm guessing you may not have an oscilloscope available either. So without a watt meter or an oscilloscope, perhaps your best bet is to just estimate the power factor (I would guess 0.75, realizing that it might be lower) and then calculated the power as Voltage (Volts RMS) * Current (Amps RMS) * PF.
    12K AG installed 2008, 150SF Cartridge filter, 2 HP 2-speed pump, Blaze pool cleaning robot
    Zodiac Nature2 sanitizer + chlorine dispenser, Hayward gas heater
    Jul 2012
    Whidbey Island, WA
    397
    Re: watt
    interesting
    electrician is coming to discuss generator
    will ask that he bring watt meter as well
    thanks
    Re: watt
    Toolkit makes a good point about the power factor.
    Many new pumps use a run capacitor, which corrects the phase shift caused by an induction motor. Therefore, the pump might have a power factor very close to 1.0. I think that all Whisperflo pumps use a run capacitor.
    Either way, as toolkit said, the best way to tell is to use a wattmeter, or a power quality meter, which can measure volts, amps and real watts, and tell you your actual power factor.
    Support the site
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: watt
    A couple of other options to determine energy use:
    1) Use the house power meter. Take a reading with the pump on and off and the energy use is the difference. This can be done with analog meter as well but it requires counting the turns.
    2) A rough estimate for the WFE 4 is about 1800 watts for 2" plumbing and 1700 watts for 1.5" plumbing.
    3) I get can get a closer estimate with a detailed description of your suction side plumbing (pipe sizes, lengths, number runs), filter pressure and pump height relative to the water level.
    Mark
    Jul 2012
    Whidbey Island, WA
    397
    Re: watt
    Quote Originally Posted by mas985
    thank you
    1) person from the energy company did that yesterday with the meter; reported 3.5 kWh / hr so if 6hrs / day and 30 days then 3.5 * 6 * 30 or 630 kWh / mo and at say 10cents per then $63 per month
    2) now say 1800 watts then 1800 / 1000 * 6 * 30 we have 324 kWh which does not match; wonder what is wrong?
    3) cannot do this as was built in 1979 and all design long gone and I am a newbie
    Re: watt
    Quote Originally Posted by engrav
    3.5 kW is not a realistic value for a 1 H.P pump. Can you get voltage and amperage measurements?
    Note that voltage measurements need to be taken under load to account for voltage drop due to load.
    Is the pump wired 120 or 240?
    Support the site
    Jul 2012
    Whidbey Island, WA
    397
    Re: watt
    Quote Originally Posted by JamesW
    wired 240
    he used the meter, is digital with little ticks passing by
    if I knew how to count ticks, I could go repeat the test
    will scan the web to see if web says how to count ticks
    Re: watt
    If you're using the house meter, you have to measure with the pump off and then on. You also have to make sure that all other power use stays the same. If any thing else changes, such as an electric water heater, or AC unit turning off or on, then the test won't be valid.
    Support the site
    Jul 2012
    Whidbey Island, WA
    397
    Re: watt
    went to the house (house is unoccupied, dark, fridge on)
    has digital meter
    kh says to be 0.6
    indicates meter runs in 80kw units / not 1kw units
    turned on the pump
    the indicator jumped rightward in 5 steps in 1min14sec; then returned to the left;
    then waited for another cycle
    the indicator jumped rightward in 5 steps again in 1min14sec; then returned to the left
    turned off the pump
    indicator jumped rightward in 5 steps in 8min42sec and returned left
    what does all this mean? dunno, beyond my old brain, electrician coming Wed, hopefully can sort out
    Jul 2012
    Whidbey Island, WA
    397
    Re: watt
    and
    Jan Feb use 1600 kwh
    Mar Apr used 1280 kwh
    May Jun used 1440 kwh in the house
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: watt
    wired 240
    That sounds like an analog meter and not a digital. I think he just used the wrong conversion factor because half of 3500 watts or 1750 watts is about right.
    If you can get the meter model#, you can look up the conversion factor.
    Mark
    Jul 2012
    Whidbey Island, WA
    397
    Re: watt
    [attachment=0:3hp7ttmw]DSC_9217.jpg[/attachment:3hp7ttmw]
    wired 240
    If you can get the meter model#, you can look up the conversion factor.[/quote]
    is digital, see pic attached
    little black lines under #'s tick by in 5 steps then return and start over; maybe this is one revolution of the analog disk
    NOTE: multiply by 80 as per written in #, kh is 0.6
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: watt
    So my meter (similar to yours) shows the actual wattage. Why do you need to count the ticks?
    Mark
    Jul 2012
    Whidbey Island, WA
    397
    Re: watt
    It reads in 80 kW jumps so the digital may not change for a day
    Re: watt
    I think that your meter alternates between displays. All 8888s is to show that the display is working. Then it shows total kWh, then current power usage.
    Support the site
    Jul 2012
    Whidbey Island, WA
    397
    Re: watt
    only two displays
    1) 888's
    2) total kwh used
    but #2 is in 80kwh units so does not change often
    the little black lines tick along throughout
    am still confused about kWh consumption
    Re: watt
    Your power company or the meter manufacturer (Landis Gyr) should be able to tell you how to read the meter to get current power use.
    Support the site
  20. Back To Top    #20
    Jul 2012
    Whidbey Island, WA
    397
    Re: watt
    [attachment=0:13i1mu3z]photo2.JPG[/attachment:13i1mu3z]
    Can you post a picture of the meter with the other display?
    sure, first is 8888 etc
    second is attached, counts in 80kwh units so does not advance very often
    I am thinking 6 jumps of the little bar is one beat (or one old analog rotation)
    then on the web site <http://michaelbluejay.com/electricity/measure.html#beats>
    enter 0.6 kh 2 beats in 148 seconds and multiply by 80 and get 2.3 kWh/hr
    which suggests the pump is 2300 watts
    2.3 kwh/hr for 6hrs for 30 days is 420 kWh / month, at about 10cents per, that is $42 per month
    but still a little uncertain
