Results 1 to 13 of 13
Thread: adding solid CYA to the pool
    I have read that if you add solid CYA in a sock through the skimmer, it takes about a week before you will get a good New CYA reading. I have also read where folks recommend putting the sock filled with CYA in front of a return jet in the pool......when it is done this way do you still have to wait about a week to get a new good CYA reading, if not about how long......Thanks, John
    16100 gallon rectangle pool built in 1984 including a 5' X 5'x 3' Spa, Diamond Brite in year 2000, Non-SWG Pool
    Butterfly's Avatar
    South Carolina
    10,045
    Re: adding solid CYA to the pool
    It takes about the same amount of time.
    Solid (actually granuals/powder) will slowly dissolve in a matter of days. But, how many days depends on your equipment, run time, water temp, etc (all those danged variables). It could take up to a week for it to fully dissolve and test correctly.
    That's why we recommend "about a week" so that you don't test too early and waste reagents unnecessarily.
    btw, we recommend hanging the sock in front of a return so that you don't take a chance on blocking the skimmer
    You're done SLAMing when:
    Many thanks for the explanation, Now I understand why I read the two different ways of adding the solid CYA.
    Should I still run the skimmer pump 24 hours while adding the CYA in front of the return jet the first day or is about 12 hours fine before returning to running it 6 hours daily? John
    30,419
    The more water that flows over the CYA, the faster it will dissolve and show up in your test results. I would run the pump 24/7 until the CYA is dissolved.
    If I understand you correctly, then once the CYA has desolved in the sock at the return jet , then if I run the pump another 12 hours, I'm then OK to return back to my usual 6 hours a day. Correct. John
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,602
    I can dissolve almost 2 pounds in summer with it in a pantyhose lying in the skimmer basket in half a day easily. Just don't backwash for a few days.
    So how long do you run your pump after it's all resolved? John
    30,419
    Run your pool as long as it takes to keep it clean....it's a learning experience. Generally, we suggest to start with twelve hours if the pool is new to you and then get shorter and shorter until you notice it's not keeping your pool at the appropriate cleanliness.
    My pool is about 10 hours in the middle of the summer....much lower in the dead of winter.
    Many thanks, that helps, John
    Mar 2013
    Clewiston, FL
    8
    So is solid CYA the best way to go or liquid(prob more $$)? I run my pump about 10 hrs a day,I was planning on running the pump 24 hr after adding CYA
    2013 11k gal freeform, in-ground, Gunite
    Hayward VS Ecostar pump,
    Hayward SWG, DE filter
    30,419
    I think liquid is about triple the cost of the granules.
    It has the advantages of being testable within a few hours and pretty hassle free to dose your pool.
    Mar 2013
    Clewiston, FL
    8
    That's what I was thinking. I'm in no hurry
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    It is really hard to justify the cost of liquid Cya, and there is no hurry to test it. Just give it the time to dissolve and test.
    Essential Links:
