Thread: Is this a correct D.E. calculation?
    Jul 2012
    CA
    240
    "Filter square footage divided by 5 equals number of scoops or pound coffee cans of D.E. to skimmer"
    Got this online...
    So my really old big D.E. filter says 72 SQ. FT.
    72 / 5 = 14.4
    I only put 5 pounds after I hosed down grids(yuk!)
    Should I add more? 14.4 pounds seems like a lot...
    if it matters- whisper flow, 30k/spa
    25k I/G ecostar ccplus Polaris plaster
    22,553
    Re: Is this a correct D.E. calculation?
    You got a make and model on that filter?
    I just looked at two different DE filters and an 80 ft² takes 8 lbs of DE and a 72 ft² takes 11 lbs, so I don't think your rule of thumb is very accurate. However since a 1 lb coffee can holds about 1/2 lb of DE I'd say you're in the ballpark. I might add another couple of lbs since you broke it apart and cleaned it.
