Thread: no more brush vac etc
    Jul 2012
    Whidbey Island, WA
    397
    Hi
    So have the winter cover on and running pump 6hr q day. Chemistries are fine as per TFP.
    So now no more brushing and vacuuming, true?
    Just watch chemistries, clean baskets, remove water as it rains, backwash, true?
    Thanks.
    IG under fir trees and one cherry surrounded by grass built in 1979, 30k, plaster, old Sta-Rite HRPB30, 4.9 sq.ft, 20 GPM/sq.ft., but with new glass, new (in 2012) 1 HP WhisperFlo one speed, new (in 2013) Rainbow tab chlorinator attached at the top, old Maxi-Flo Heat Exchanger MF-260, Burnham V7 oil heater 245 MBH, new (in 2012) Compool to Easytouch, Taylor K-2005 and TF-100.
    Aug 2013
    Oklahoma City, OK
    140
    Re: no more brush vac etc
    Why not just winterize the pool?
    20000 Gallon, Sand Filter, IG Plaster, Hayward Aqua Rite 40k SWG, TF-100 Test Kit, Taylor SpeedStir
    Jul 2012
    Whidbey Island, WA
    397
    I wondered about that but don't know what it means. I guess time to read up on TFP. Thank you.
    30,431
    Depends. If you put a cover on it, then no, If you leave the pool open all winter then you should maintain the pool just like you always do. You can have your chemistry right, but mechanical cleaning and removal of debris is a 12-month operation......just somewhat less of it in the off-season.
    Jul 2012
    Whidbey Island, WA
    397
    Checked with my local pool guy, the one I trust. He say
    in the Pacific NW rarely freezes and rains a lot refilling the pool so most just cover, turn the pump to less frequent and remove water when too high
    do not know enough to debate the topic myself
