Thread: Will Acid remove tile scale?
    Jun 2013
    Southwest Arizona (Yuma)
    125
    I am planning on draining and doing an acid wash on the pool this off season. I have scaling on my tile as well so Im wondering if the acid will removed this as well or do I need some other product?
    My pool:
    Built 2004, 14K gal, IG plaster,Pentair WhisperFlo 2 HP pump(1 speed), Pentair FNS Plus DE filter,
    In Floor cleaning system, Attached Spa with Spillover seperate WhisperFlo pump for jets.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Will Acid remove tile scale?
    Quote Originally Posted by JT2006
    Bead blasting would be a better way to get the tile clean. There is a before & after pic of the tile toward the bottom of this post: http://www.troublefreepool.com/acid-...el-t54848.html
    Jul 2011
    Arizona & California
    805
    To answer your question, yes, acid removes calcium scale off of tile.
    However, BoDarville is correct that bead or sand blasting may work much better.
    And that is because "scale" above the water line often contains ingredients other than calcium which are not easily dissolved away by acid.
