Sep 11, 2013
176
Cocoa, fl
Getting used to my tf100 and had a question about the cay testing procedure. It says to use one "..heaping" spoon full. This spoon is very tiny and you really can't get a heaping spoon full unless you stick it in there and have it on the handle of the spoon also.
So I was wondering if you can describe to me the proper amount in this spoon being that a little to much or too less will have different readings.
Thanks
You must mean the FAS-DPD chlorine test (not whatever "cay" is ;) )
The amount of powder is not critical as long as you have enough. Too little and the test can give odd results. Just be sure to start with a good pink color and you are usually fine.
