Thread: micro-bubbles
    micro-bubbles
    I have a 25,000 gallon pool i just started have small micro bubbles that look like my water is cloudy. it's a indoor pool my water readings are
    chlorine 4.5
    PH 7.4
    alk 130
    hardness 300
    Please help thanks
    22,553
    Re: micro-bubbles
    Welcome to TFP.
    How do you chlorinate the pool?
    What type filter do you have?
    What all have you added to the pool prior to this starting?
    What all have you added to the pool since it started?
    What is your CYA level?
    How did you get those results?
    Re: micro-bubbles
    I have a ecolab test kit to get my results.
    I have a sand filter model s270t hayward I also have a chlorine feeder tablet
    I also have chlorine tablet style auto feeder
    Re: micro-bubbles
    I do have an equal lab pool controller that controls muratic acid and chlorine into the pool I test every day and calibrate controller
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: micro-bubbles
    Do you also have solar?
    Mark
    38,507
    Re: micro-bubbles
    Please add your pool details to your signature and location to your profile as described HERE as it will help us help you.
