Thread: Hayward EcoStar Timer Deactivation Tip
    Jul 2013
    Puerto Rico
    76
    All,
    I had to deactivate one of the timers and could not find the info on the Operation Manual so I called Hayward.
    To deactivate a timer just set the timer to start and end at the same hour (Start at 8a, End at 8a), save the setting and you're good to go.
    Pool: 6,500gal Plaster (Pool & Spa), Capsule Shape, 25ft x 8ft, 3ft to 5ft depth
    Spa: 6ft diameter, 3ft deep
    Equipment: Hayward DE3620 Filter, EcoStar VS Pump, Aqua Plus Controls & SWG
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Hayward EcoStar Timer Deactivation Tip
    Thanks for posting as I'm sure someone will benefit. Lot's of Ecostar questions do seem to pop up.
    Essential Links:
