Thread: Add 2nd pump to improve circulation?
    Could I add a 2nd pump and hook it up inline with my Intex Krystal clear 635T Filter pump with the hopes to improve water circulation?
    5,000 Gal. Intex Ultra Frame 16' X 48" Round
    W/ Stock Intex 1500 GPH Filter/Pump
    Purchase June of 2013
    22,549
    Re: Add 2nd pump to improve circulation?
    You're better option would be to change the existing pump and filter out for a 2650 sand filter and pump.
    Mid Missouri
    227
    I agree; upgrade to the Intex 2650 sand filter. I did after 1-1/2 summers with their cartridge filter system. I wish I had done it sooner.
    18'X48" Intex Easy Set, 2650 GPH Intex sand filter, Intex SWCG, Intex deluxe skimmer
    Jun 2012
    MA
    347
    I parallel would be much better than in line. I use two intek cartridge pumps and it works great.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by DrtBikDave
    That would be a bad idea if you are talking about adding just a pump to your current pump/filter, since the flow rate of you current pump is already to high for that size of filter cartridge. See: http://www.troublefreepool.com/sand-...0.html#p581878
