Thread: HDX Germicidal (8.25%) vs Outdoor Bleach
    Jun 2013
    Austin, TX
    70
    Hi I am traveling and my wife picked up the Outdoor HDX bleach, not the 8.25% Germicidal. Other than being more expensive and weaker , are there additives that would be a problem? I don't see anything on the MSDS, but I'm not sure. Thanks!
    12k gal IGP/Spa, gunite, Jandy 2HP ePump VSP, Jandy CL 460 Cartridge Filter, LXI400 Heater, PebbleSheen, Polaris 280, stenner 45MPHP10 auto chorine feeder
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: HDX Germicidal (8.25%) vs Outdoor Bleach
    Yes, they have soaps/detergents in them. I would not advise using them in the pool at all. Take them back, or save them for scrubbing up the patio or some such thing.
    Essential Links:
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    I looked at this HDX Outdoor Bleach MSDS and do not see any additives either. However, note that not all ingredients are required to be listed on the MSDS. For example, look at these two pages from the Clorox web site (scroll towards the bottom of each page below):
    Outdoor Bleach
    Regular Bleach (what we recommend)
    Note the difference in the ingredients. In particular, the Outdoor bleach contains two ingredients that the Regular bleach does not: (1) Cetyl Betaine (a surfactant and thickener) and (2) Sodium Xylene Sulfonate (co-thickener).
    Now, if you look at the MSDS for Outdoor and Regular bleach, both list the same ingredients.
    So as for what to do with the HDX Outdoor Bleach...To be totally on the safe side, I would either return it or use it for the laundry or other cleaning needs.
    Jun 2013
    Austin, TX
    70
    Ok, thanks! We will return it.
    Aug 2013
    dallas,tx
    79
    I think the HDX outdoor bleach is labeled wrong on the three bottle box. After I had already used 2 quarts, I realized I had the wrong item. Took back and exchanged for another case and was cautious to get the germicidal bleach label on the box. Got home ready to pour in pool and had the outdoor again. Back to home depot, will get 3 separate bottles this time
    2009 19k, IG, Quartzscape negative edge w/waterfall, 8' raised spa w/waterfall ,Pentair WF28 2hp, Jandy 1.5hp pump for water fall feature, Polaris 280 cleaner with booster pump,400,000 Jandy LXI heater, Jandy DE 60 filter.
