Thread: Pool Calculator Question
    Using the Taylor 2006 test kit and testing ph, is there a way to go directly from the number of drops needed to the "Pool Calculator" for a recommended adjustment? My first test was above the darkest ph color so I am not sure what the ph is, but it took 3 drops to get where I wanted. I could use the Taylor Chart ... but would rather use the calculator...
    Thanks!
    Swim-Ex 400 paddlewheel swim spa - 3000 gallon -Pentair CCP-320 - Coates 11KW heater - 1/2 hp pump - Outside in pit
    38,406
    Re: Pool Calculator Question
    Nope. You will have to use the chart if using the demand tests.
