Loop loc cover -- Anchor Question
Jul 18, 2011
10
Hi guys and gals!!
So I have a loop loc cover on my in-ground pool and there are about 6 -8 of the brass anchors that are stripped and I can't get them to screw in or out or are generally destroyed. So I have a bunch of straps I cant secure down.
My question is, does anyone know if the brass anchors can be totally unscrewed? If I bought some new anchors would I be able to transfer the screw from the new anchor into the old one?
I REALLY don't want to have to chip out or put new anchors into the concrete!!
Thanks in advanced!!
Yes you can take them out. I pull mine out in the spring and wash out the holes.
I had to replace an anchor. I welded a lag bolt to a nut and put it on a slide hammer. Threaded the blot into the drain hole. The anchor comes out pretty easily.
ok cool, pool store tried to tell me they are one piece so I just wanted to make sure
Thanks for the help and good tip on pulling them out in the spring. Would be a great idea to pull them all out, clean and grease them.
