Did you pour the CYA directly into the skimmer or is it in a sock in the skimmer basket ?
pwrstrk said:Did you pour the CYA directly into the skimmer or is it in a sock in the skimmer basket ?
Not singling you out but I am trying to disspell the notion that rain makes large changes in your pool water....it almost never does.TN94z said:It also looks like we are going to get a lot of rain today as well....
duraleigh said:Not singling you out but I am trying to disspell the notion that rain makes large changes in your pool water....it almost never does.TN94z said:It also looks like we are going to get a lot of rain today as well....
A 2" rainfall into the average pool should change your numbers by less than 5%. I am sure there are some outliers (and folks will rush to post them up) but most rain events can be disregarded. I have no explanation why this "urban legend" is so prevalent.
TN94z said:Will do. I haven't had it tested the last couple of weeks because we have been trying to get all of this dirt out. I had just added chemicals before all of this happened. I will post up results as soon as I get some more current ones. Sorry.
fannd said:TN94z said:Will do. I haven't had it tested the last couple of weeks because we have been trying to get all of this dirt out. I had just added chemicals before all of this happened. I will post up results as soon as I get some more current ones. Sorry.
Do you cover your pool in the winter?
Brushpup said:Let it all dissolve, and test a few days after that.
linen said:Have you had to backwash since putting the cya sock in the skimmer?
TN94z said:Brushpup said:Let it all dissolve, and test a few days after that.
Are you referring to what is already circulating? Because I took the stabilizer in the sock out a couple of days ago.
jblizzle said:They put 60-70ppm worth of CYA in the sock ... and were advised to remove the sock since you only want around 30ppm for the SLAM process. Sounds like not enough has dissolved yet.
