Will do guys. I am still learning so I just assumed the pool store tests were okay. I'll post the results tonight
jblizzle said:If the yellow OTO was basically clear, that means you have very low chlorine in the pool ... so your FC and CC are doubtful from the FAS-DPD test. It should start from a pretty good pink if there is chlorine in the water.
You need to lower the pH, raise the FC, raise the CYA, raise the salt ... BUT ... I have no idea the proper way of using floc, so no idea when you can do what.
jblizzle said:Lower the pH with muriatic acid
Raise the CYA with stabilizer (this will also lower the pH some)
Adding more salt will not increase the amount of FC output. You have to increase the % output and/or lengthen the pump run time to increase the SWG FC output.
But, as brushpup said, you need to complete a proper SLAM without the SWG before you start dealing with that.
Brushpup said:Look on the acid bottle and find out what percentage it is for strength and choose that one.
heythatguy said:Sand filters will filter down to 25 microns, therefore missing a lot of small pool particles. DE will filter down to 4 microns, and a cartridge will filter down to 15 microns. That is why you would use a clarifier, or a floculent, to vacuum the pool. There is a products called fiber clear that will filter down to 2 microns and washes clean much easier that DE.
jblizzle said:heythatguy said:Sand filters will filter down to 25 microns, therefore missing a lot of small pool particles. DE will filter down to 4 microns, and a cartridge will filter down to 15 microns. That is why you would use a clarifier, or a floculent, to vacuum the pool. There is a products called fiber clear that will filter down to 2 microns and washes clean much easier that DE.
Rarely are the use of clarifiers or flocs recommended by this forum as they can sometimes cause more problems than good.
Any filter can successfully have crystal clear water. The use of a little DE in a sand filter can help speed the clearing process if required without the need to put unneeded chemicals in the pool.
Bama Rambler said:The problem with floc is that sometimes it works and sometimes it doesn't. That's not our definition of trouble free. Besides in a properly manitained pool it's just not needed. Clarifier works better than floc but it's only recommended in special rare cases.
Bama Rambler said:Personally I would run an OCLT tonight at normal FC level and see what it showed and decide from there.
