Thread: drain in the center of an above ground cover..
    Trying to think of ways to deal with the water that may collect in the winter cover of my 15 x 30 AGP.
    does anyone thing that putting a hole in the center, attaching a hose to the hole somehow and running the hose over the edge of the pool would work?
    Swim 'N Play Deluxe 8000 15 x 30 (buttress free, vinyl)
    13,500 gallons
    Hayward horse and a half pump
    Hayward sand filter
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Re: drain in the center of an above ground cover..
    I think that if it freezes it will stay frozen longer than the water on top. A cover pump is the normal way people handle this situation.
    Sent via Tapatalk...
    22,553
    There are covers that have a drain in the center and the drain hose is routed out the return fitting when it's disconnected. The drain hose has to be below the center og the cover for it to work.
